Does the belt not also drive the aircon and power steering?
Have you checked to see if turning thr aircon off makes a difference?
Mine also make this noise but only after i have put my foot down. Let me know if you find out what it is ?
Audi S8 Phantom Black |
That's just the wails of the dead dinosaurs you're burning screaming through the years
Could be the aircon compressor, try shutting the whole system off or try selecting econ mode to disable the compressor.
Tried all of the above it definitely dose it in every selection D P R N S all of them and ive also figured its definitely not the gear box because if I nock it in two neutral on the move its still only in time with the engine revs not road speed :s
Confused now ... Can only be eather Air con pump Power steering pump Altinator Or auxiliary belt tentioner Well...I guess any way |
Mine is the same Daviebike. But not aircon as still does it with that declutched, and could be the vacuum pump for the brakes (and maybe EGR), or hydraulic pump in the auto box as that runs in N too.
Mine does it but goes off when I shut the a/c off. Must be a/c pump in my case. I've got used to it, did **** me off for a while though.. I'm sure it'll **** me off again at some point when the a/c packs-up
07 Silver D3 A/S8L Quattro ![]() ![]() |
