Old 10th March 2014, 10:30 PM
Can't see why they would not fit. PCD is the same 112mm, centre bore might be bigger at 66.1mm instead of 57.1mm but you can use spigot rings. And it will be harder to kerb them as they are narrower tyre will hit the kerb first.
