Hi Guys,
Fuel pump out. Housing split reasonably easy if a little confusing quite which clip undoes. Seeing it does come apart and is designed to, i find it odd Audi doesn't sell the pump. Part code 4D0906091C on it Net search brings up a few places. inc world parts. However reading http://forums.audiworld.com/showthread.php?t=2748849 Makes things more confusing. However http://www.ignitioncarparts.co.uk/se...2001Z&cmdGo=Go Is the recomended one from that page. About £150 delivered. I find it odd that there would be two with the same part code. But i'd prefare not to have to return it. I'm also a tad nervous as my 2000 S8 isn't mentioned, nor the AVP engine code....Argghh Lee |
That code throws up this page on worldcarparts.
If you check the oem codes: PFP405052002001Z - on ignition car parts and VDO 405-052-002-001Z - on world car parts I would say they are the same component. It looks like the answer to a maidens prayer with regard to fuel pump issues. If you can Lee, a how-to on what you do to change the pump would be very very useful.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. ![]() Last edited by Conan_the_Librarian; 27th August 2009 at 09:42 AM. |
Hi Conan,
Read the above linky....The audiworld one....Seems to think the car parts one although having the same code is not correct ! Oh and i've taken it into a small LPG place in huntingdon who is doing the work....The Large LPG tank was in the way which was why Audi huntingdon didn't want to touch it, not that they mentioned this when i booked it into them with a fuel fault !!! I may drive down to Essex to ignition parts with the old one and pick on up or just gamble it over the net. cya, Lee |
I'm told by Audi Technical that the pump is not available separate due to the new one having a modified delivery unit/level sendor as well as different pump. This apparently cures some issues with cracking and drawing in air to the fuel system that the old one can be prone to. Saying that, the last couple I've seen had old ones and no cracks. I did however on Tonupkids, have to replace a couple of seals on the pick for the pump. This is about 4-5inches from the bottom of the tank. It draws from a network of pipes and small filters that allow fuel from both sides of the tank to be drawn on. If this seal goes then air is sucked in and will cause loss of power at high load. I would assume area like this are remedied on the new units.
Hi There,
So your saying that its Audis sneaky way of getting round a product fault and getting the customer to pay for thier mistake....Nice ! To be honest i run on LPG 95% of the time, lack of power at full load....You mean i'll only get 150 not 155mph ??? cya, Lee |
If you're on LPG your fuel pump has an easy life, if the car works I wouldn't worry!! ![]() |
Hi There,
I've gone for one of the ignition car parts ones....Its a siemens and was next day delivery before 2pm for £145 delivered. Audi UK doesn't have one and was quoting 5 days from Germany. The old one lasted 9 years and would have probably done better if i hadn't run out of petrol due to issues with battery/fuel guage and if i'd have though more about the non starting issue when it occured. I think i effectivly ran it dry and burnt it out. cya, Lee |
