Old 13th March 2014, 09:30 PM
GH77 GH77 is offline
Default Upgrading from Concert cassette to RNS-D
Evening all,
Just looking for a bit of top-line advice. If you can help me get started I'll be able to find the detail myself.
I've got a FL 2000 Bose Concert single DIN cassette unit in the car which has stopped working. It only goes off or very quiet. From reading up on the problem, I believe I've reached my 10,000 twiddles of the knob and the EPROM chip is no longer writeable. Anyway, that's a good excuse to upgrade as I've always wanted to do that.
The two options I've got available for me to buy (from a8 parts) are:
4D0035192E
or
4D0035192K
What do I need? I know that I need (and can get)
Double DIN cage
Double DIN fascia surround
GPS unit
What extra cabling / connectors will I need? Will this be plug-and-play to any decent extent?
Thanks in advance for any advice you can offer!
Gregor
2000 FL A8 3.7 QS - Turned 21 years old on 15th March 2021. Ming Blue - 175k miles. I love having a 90's car worthy of 90L of 98 RON! If only they still did 4* fully leaded!
2009 A8 4.2 FSi LWB - Marine Blue - 164k miles. Extras? Too many to list. But I do like the Rear Seat Entertainment . . . . . .
477k miles to the moon and back. 238k to go and between them they'll have made it!
Old 13th March 2014, 11:04 PM
I've got a 4D0035192H which has the following characteristics:
Partly given to me (many thanks johnny_quattro).
Partly purchased. (cheers ScottB5)
(The top GPS and base tuner/screen are a mix-and-match, or cut-and-shut, not originally together)
The GPS drive is possibly a bit unreliable at reading the latest map CD's (copied), but OK with older (or copied) original ones (e.g. 2002/3).
The copy protection was tightened up over the years and some drives struggle to deal with the latest map CD's.
PM me if interested, just looking to cover my initial costs and postage.
As for wiring, I don't know, but IIRC it's VERY similar but don't take my word for it.
Obviously I have the code - as johnny_quattro knows only too well (bit of a saga there!)
Old 14th March 2014, 12:44 AM
Thanks for the reply. I'm not adverse to buying privately so will keep your offer in mind.
Can anyone offer a yay or nay answer on me being able to do this, please?
Gregor
Old 14th March 2014, 05:54 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
It's do able if you got the right dash.
I can't answer that side of it cause I don't know D2s that well.
But the wiring is easy.
Just needs power, speed sensor and that's assuming your speakers are the same.
[center]
06 3.0TDI Quattro:
Options:
Old 14th March 2014, 07:51 AM
Cheers, Scott.
I know I can do the dash (he says confidently) so if you think that the wiring etc is straightforward then the plan's a goer........
Any other last minute advice out there for me, please?
Old 14th March 2014, 08:00 AM
Have a look online for some details of the connectors on an RNS-D, there's plenty of info.
I though I had some saved on my PC to add to this post, but can't find it.
This thread might help: http://audisrs.com/archive/sat-nav-s...__t_40931.html
Old 14th March 2014, 08:06 AM
Awesome. Thanks. If you find the links, please post them!
Old 14th March 2014, 08:15 AM
I think that thread says everything I have, apart from some gory details of the TV and CD connectors at the other end (in the boot).
If you have Bose you need to code the RNS correctly or you will only get sound from 2 speakers.
Old 14th March 2014, 08:38 AM
Thanks again. Have got access to VCDS when the time comes.
Have sent PM re your kit.
Old 14th March 2014, 09:04 AM
Have replied to PM.
As noted, the SatNav part of what I have was purchased from ScottB5. He has a "selection" of RNS bits and pieces for sale.
