Old 15th March 2014, 06:24 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default D3 VCDS List
I've had a search and I can't find anything.
Do we have a list of VCDS tips, tricks and such that can be done on the D3?
If not, would it be worth compiling one?
I'm back home on Sunday and going to have a proper look through VCDS and see what I can do.
If we don't have a list I'll mark down here all the bits I've done.
[center]
06 3.0TDI Quattro:
Options:
Old 15th March 2014, 03:50 PM
The ross-tech wiki is pretty good for what can be done.
Old 16th March 2014, 11:06 AM
ScottD3's Avatar
I'll take a look through that later.
Thanks.
I have a quick play today and noticed a couple of things.
07 - Control Head
10 - Adaption
Channel 02
+8 = Oil Level Display.
I got the battery display, what's the oil level display?
I got a tow bar and in the tow bar section of VCDS there is a option for multimedia display.
Any idea what that is?
[center]
06 3.0TDI Quattro:
Options:
Old 17th March 2014, 06:44 AM
Oil level display will not display anything, since its use is intended for those cars who have no dipstick. I believe it can be made to work once enabled but you'll need to replace the oil level sensor with one that will provide a level rather than the simple on/off version fitted already.
Old 17th March 2014, 07:01 AM
ScottD3's Avatar
I'm not going to be doing that.
I did that on my last car to get a cluster working.
Not prepared to go that deep on this one............He says as he's looking at TPMS, reversing camera, radio clock, DAB and digital TV.
[center]
06 3.0TDI Quattro:
Options:
