First time since looking at the car I've been able to have some alone time with the car, a proper dig and VCDS scan time.
First, up some fault codes that I had when I got back from Bristol. 005658 - Glowplug for Cylinder 1 (Q10) P161A - 001 - Open Circuit 001025 - EGR System P0401 - 002 - Insufficient Flow 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground 00192 - Rear Left Door Handle Touch Sensor (G417) 007 - Short to Ground - Intermittent 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit - Intermittent 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent 01598 - Drive Battery Voltage 002 - Lower Limit Exceeded - Intermittent 02111 - Motor for Window Regulator 004 - No Signal/Communication - Intermittent 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent 02272 - Quiescent Current Stage 1 000 - - - Intermittent Cleared all fault codes and only two came back. 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal I'll do another full scan tomorrow after a little drive. I'll take a look at the two that came back but it looks like its just connection issues? Having a look around the boot sides I noticed this cable going down through the rear air vents. ![]() ![]() The HPI check came back saying it has a tracker, it could be that. I need to phone the tracker company to make sure but anyone got any ideas? The tool kit is looking a little sparse and needs filling up. ![]() I've got what I think is a Audi detachable two bar but I don't know where it is mean to go for storage. What am I missing? ![]() There is also this connection in the glove box. I've been told that it could be a Dension 500 gateway kit but I'm not sure. Can anyone confirm? ![]() It works fine with the iPod but I'm not sure how the USB or RCS connection works but I'll have more playing about with that later. There is a couple of little bits I need to pick up over the coming weeks but mainly I need to give it a good clean.
