Old 23rd March 2014, 06:36 PM
Mine was fairly active yesterday when I went to get something from the car.
Is this an early or late model panel?
I notice that my FL S8 with the later panel is much "livelier" than my PF was with the earlier design.
As an aside, I had been wondering whether to fit a cutoff switch so that it only operates on days when I want it to, usually when out for the day and parked in the sun.
Would that be relatively easy and where/how would you do it, presumably in the control circuit?
Old 23rd March 2014, 06:45 PM
I have late model panel with 4 courses of cells.
You can easily install switch that will simply cutoff the "+" wire from sunroof before it enters the relay. I'm going to install that switch later, but will use it to toggle between trickle charging mode and blower mode
Old 24th March 2014, 07:49 AM
You can hear mine running on a sunny day. A switch is a good idea, cos they're not so good when it's cold and damp (but sunny) as it tends to mist up the car a bit.
Old 24th March 2014, 08:03 AM
Mine is whispering away right now; 9am and sunny though only 3C so rather pointless.
Old 24th March 2014, 08:09 AM
If you're not convinced it's doing anything you could shut all bar one of the vents to try and increase the flow of air to that one vent?
