Old 23rd March 2014, 09:22 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
The mirrors and window don't look associated on the wiring diagram.
Here are the rear window fuse and relay.
If you turn on the rear window, does the LED on the switch stay on?
Does it affect DAB or FM reception?
I don't understand how they can't be associated when they are activated by the same button?
Fuse is fine and relay replaced
Light stays on and doesn't seem to affect reception
Ruddy cars! lol
Whenever I've had heated mirror issues I've always done a couple of simple electrical checks:
Take the offending mirror off and check for voltage (12V or so) on the connectors and check the resistance of the mirror between terminals.
I'd expect the resistance to be under 10 ohms. Much higher and it won't take enough power to warm up much.
As it happens it's always turned out to be failed mirror(s), on several cars including my old S8 (newer one is OK at present, though the heated rear window is quite "slow").
My S8 mirrors are nuclear-powered though - they start steaming in seconds!
My Mirrors were always amazing also...thats why I miss them so much.
I'll check for power-not thought of that. (DOH-Blonde!)
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 30th April 2015, 09:26 AM
A8L Chick's Avatar
WOOOOO HOOOOOO
Guys I forgot to say that this problem is fixed!
I do feel rather stupid though... it was the connection behind the drivers side mirror.
So I wiggled the wires and voila, it started heating up! As did the rear screen and the n/s mirror.
This was all on Christmas evening.. Best xmas pressy I got
I have a feeling that the mirror had received a hard enough clump from someone to make a poor connection... what a shame I didn't check this sooner! I literally checked everything else!
Old 30th April 2015, 09:46 AM
That's got to be the luckiest find ever, how the wiring behind the mirroe effects the rear demist is a strange one.
Old 30th April 2015, 10:26 PM
Well done Bex.
Give that Gal a big prezzy.
This is the odd ball sort of thing that makes A8 ownership so interesting.
Have to keep this one warm for future reference.
Old 30th April 2015, 10:34 PM
Score....but a weird one, well done
Old 11th May 2015, 12:38 PM
centurion centurion is offline
hi... i have the same problem as my heated mirrors do not work hence was wondering how to remove mirror cover - what is the best way to do so and what tools to use?
Old 11th May 2015, 12:57 PM
have a look at page 175 & 176 of THIS PDF
Old 20th October 2016, 10:57 AM
BLAKEY BLAKEY is offline
A8L Chick
I've had this issue since I got my 8 and came across your post whilst browsing for a solution. I was a bit worried about popping off the glass at first but it was a lot easier than I expected. Wiggled the wires as you said and viola it started heating up. Thanks for the Tip!
Blakey.
2006 D3 A8 4.2 TDI. SPORT. Nite Blue.
Old 20th October 2016, 02:46 PM
Originally Posted by BLAKEY View Post
Thanks for the Tip!
Blakey.
Wow - will have to try this, my driver's side has always been very weak compared to passenger's.
