Old 28th March 2014, 06:38 AM
Message to the mods - Thread needs to be moved, I think!
Old 28th March 2014, 07:31 AM
Palmer Palmer is offline
Ahhh ****e i posted in D2! LOL
Old 28th March 2014, 10:49 AM
It was the mention of PCBs that alerted me to this! Just old fashioned bulbs and wires on the D2s!
Old 28th March 2014, 01:04 PM
I have a small amount in one of my rear lights, but only the reversing section. The LED area is perfectly fine and dry.
Old 28th March 2014, 01:23 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I got exactly the same thing with mine.
need to strip them out and take a look and see bout resealing.
[center]
06 3.0TDI Quattro:
Options:
Old 29th March 2014, 07:05 PM
Happening in both wind lights and the reverse lights in the boot too.
How would one go about resealing them? Or rather what would you use. Had a look today and they look like the come out fairly easy....
Old 30th March 2014, 07:14 PM
My wing-ones had this. You can take them out by removing the 10mm? nuts behind plastic caps. These are located beside the lamp when the boot is open. There are cut-outs with caps in the plastic boot aperture trim.
Be careful not to drop the nuts as they will fall into the bodywork.
A magnetic pickup tool is good for the last few threads.
You can then remove the lamps , remove covers and dry them in a warm place or maybe top oven while the bottom oven is on minimum.
Clean the seal of the covers and mating surface. Apply a tiny smear silicone oil if you like. I put silica gel packs in mine, you can get these from camera shops or ebay.
A year ow two later, the boot lid ones are the same but a lot more involved in removing them.
