Old 4th April 2014, 05:41 PM
Lambda sensor fault is not critical, it's just for the heater so it will take longer for lambda to start working on cold starts say 2 minutes instead of 20 secs.
The first to look at is cylinder 1 misfire and it can be causing multiple cylinder misfires. Check spark plug, ignition coil, injector and wiring for cylinder 1.
