Old 4th April 2014, 02:25 PM
Lyons Lyons is offline
Is that all that's needed?!
From the comments on the previous page I thought fitting a tuner to a car with none from the factory would be an impossible task?
Old 4th April 2014, 02:30 PM
if you have no TV or reverse camera there is another module to buy as per the text. You'll also need a FBAS compatible display interface. Kufatec will sell it to you (part 35600) for £650.
Old 4th April 2014, 02:36 PM
Crikey, missed that bit .
Old 5th April 2014, 10:59 AM
Does the display interface have component protection?
Old 5th April 2014, 11:10 AM
Yes it does unfortunately, however there is a guide on how to add FBAS to your non FBAS interface, quiet complicated and involves a lot of surface mount soldering. No need for component protection removal then, just some coding.
http://www.dognmonkey.com/audi/add-f...0-035-729.html
Old 5th April 2014, 05:28 PM
...so, if I don't have a TV at all then I will need this 4E0035729 and the tuner inc aerials and necessary cables, correct??
Old 5th April 2014, 05:44 PM
OEM aerials is almost certainly going to be a whole world of hurt.
There's a thread somewhere where IT shows how the D2 aerials are fitted, access involves stripping out most of the rear cabin. Can't imagine D3 is any easier.
Old 5th April 2014, 06:18 PM
audifin audifin is offline
Aren't the aerials on the rear screen? Which would mean you'd need new rear screen, and new antenna amplifier.
Old 5th April 2014, 06:41 PM
Don't know about D3, but on D2 they are behind the trim around the screen, 4 of them for the diversity receiver. I would expect D3 to be vaguely similar.
Radio aerial is usually part of the rear screen.
Old 5th April 2014, 08:18 PM
Aren't they located by the roof behind the roof lining??
