Old 5th April 2014, 08:49 PM
If there is at least half of the material left then more likely it was going to happen due to some poor connection issue probably and it finally, unfortunately, happened.
Unplug the connector, check for any signs of water or possibly damaged wire, dry/repair it and see.
Old 6th April 2014, 10:02 AM
Lyons Lyons is offline
Thanks. I take it you need the wheels off to check that? Couldn't see anything through the spokes.
No way to determine which corner is at fault?!
Old 6th April 2014, 02:38 PM
Light is away off again!
Old 6th April 2014, 03:02 PM
If its a loose sensor then will only be the front, no sensors on the rear but they work through the handbrake ECU which works of the pad thickness..... So only two wheels to check
Old 7th April 2014, 09:05 AM
Thanks. I spoke too soon I fear, it comes on at some point in each journey now.
I'll get the wheels off and have a look at the weekend.
Whats best to use to clean the connection?
Old 7th April 2014, 09:17 AM
Norretal's Avatar
Norretal Norretal is offline
I had a similar issue with my D2, pads were only months old so knew there was a fault rather than pad wear. It's more annoying than anything so I was determined to find it. Wheels off and cables checked for damage, connections checked closely and dried out plugs and sprayed in some WD40 and I've never had the problem since. You may "fix it" without even finding the cause but sounds like you've had some water ingress in when washing the car.
Good luck
Audi TT - 2015 - Ultra
Old 7th April 2014, 09:34 AM
Fingers crossed its that easy!
Is there an actual plug connection as such on the D3's do you know? I assume the calliper/pad won't need to come out?
