Old 13th April 2014, 01:27 PM
Palmer Palmer is offline
No ya plumb i mean for example if the battery has been disconnected completely and then a new one hooked up, will the car lose connection with the key or radio? or will some functions on the car require a dealer reset or something???
EDIT: How do you code a new battery in then?
Old 13th April 2014, 01:47 PM
I can get that same one for 120. Looks the best stats 110 amp hours and 920 cold cranking amps - without spending stupid money that is lol
Old 13th April 2014, 02:26 PM
No doubt you can get it cheaper, link to ECP was just for the spec. If you can get same discount in your local ECP than its only 10quid more but its your call mate. And yes, 110A and 920cca is what you need, BUT thats what I needed for my petrol. Just make sure you don't need slightly higher specs for diesel, not sure if it matters at all, but...
Old 13th April 2014, 06:31 PM
So i need to take it somewhere to get coded then. Is it important??
Old 13th April 2014, 06:41 PM
Well, its not critical but its there for a reason so its important to do it long term.
If you dont have VCDS then you will have to go somewhere, BUT the best possible investment you can do for yourself and your wallet as a A8 owner is to buy one, and I'm sure 99% of people here will agree
http://www.gendan.co.uk/product_VCHU.html
Old 13th April 2014, 08:27 PM
If you like, go to https://www.carparts4less.co.uk (part of ECP)
you can use the coupon SAVEME75 and the same battery is just £123.77 and you can reserve and collect from shop now, whereas you couldn't on this website until this week..
Old 13th April 2014, 08:57 PM
Vcds is vagcom right?
Am i right in thinking i can just download vagcom to a lappy then get a cable to connect to the car??
Chris
Old 13th April 2014, 02:22 PM
OK, I get it. I had no issues but not 100% sure
Here is how to do it
http://wiki.ross-tech.com/wiki/index...ry_Replacement
