Old 9th September 2009, 12:11 PM
Just_Ben Just_Ben is offline
The Lambda is a definate failure, shouls have a basic wiring check but that fault's pretty much a definate!
The load calculation will be air leak/dodgy Air Mass but Timing issue will be either faulty camshaft adjuster or cam belt on wrong......
Either way it's likely to be costing you ponies!!
