Old 14th March 2014, 08:20 AM
Lyons Lyons is offline
Ok, cheers.
Is it a new handle job, or just a sensor within it? Any idea how easy a fix it is?
Might just let the dealer sort it the next time it is in under warranty. Not a great loss though as I've never had it working to appreciate the benefit of it!
Old 14th March 2014, 09:05 AM
New handle (or at least fiddling with it from inside). Unless it's the main module, then it's more involved.
Definitely worth a warranty job if you can swing it.
Old 14th March 2014, 12:44 PM
I have warranty on my car so will get it done the next time I'm in with something else.
Old 23rd April 2014, 03:45 PM
mannyo mannyo is offline
Bizarrely out of the blue all my door handles have decided to start working properly. I no longer have to lift any of the handles for the door to unlock, just touch them and they unlock. I have no idea why they started working, all I have done recently is change the wiper linkage and motor.
Manny
Past
Old 23rd April 2014, 04:05 PM
My PF had some gremlins with the keyless which was a result of water ingress, it was always a bit dodgy after it had been raining.. Took the garage months of fiddling to work it out, and about a week and a half to dry the car properly!
Old 23rd April 2014, 06:01 PM
Where is the ECU for the keyless located, I wonder if its worth taking a look at the connections.
Manny
Past
Old 24th April 2014, 07:47 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Faulty door handles seem another common issue.
We need a group buy and cheaper handles for everyone.
[center]
06 3.0TDI Quattro:
Options:
Old 24th April 2014, 06:40 PM
Funnily enough both passenger side handles on my car have started to behave properly this last week- unlocking just as I put my hand under them.
Both drivers side handles still need lifted to unlock.
Old 2nd May 2014, 09:14 AM
Drivers door has started to work too!
Is there a specific module that controls these? I'm wondering if water could har damaged it?
Old 2nd May 2014, 09:39 AM
ScottD3's Avatar
It sounds like water is getting in and when it all dries out it starts to work again.
[center]
06 3.0TDI Quattro:
Options:
