Dont worry about flaps .. try windscreen button and feel for heat with temp on high
If there is no heat but the car sits at 90 perfectly then il bet its the same as mine in my case the picture above is the unit in question Hope it helps ... good news is there the same on the 3.7 4.2 and tdi as well .. easy to obtain but not all that cheap and a bugger to change |
You can change it at home its easy but fiddly and time consuming really.
I dont have a part number off hand but on ebay type Audi A8 heater valves .. it will come up Or try A8 parts see if they have them in stock ![]() |
Thanks, most useful.
A quick eBay search finds this http://www.ebay.co.uk/itm/02-09-AUDI...item338dd379ca |
What engine is your A8 and year ?
2003 4.2 v8 of the petrol kind
In that case. The same as mine ..
hmmm the ebay one could do with some extra pictures really ... When im next at the pc not on my mobile il have a look on elsa win for you and check there the same ... not sure if Quad zone climate v duel climate makes s difference or not |
The D3 dosent have a rest function .. but I think maybe turning it on while the ignition is off serves the same purpose ?
That unit is very similar between D2 and D3 and incorporates the auxiliary water pump, which has a habit of failing and getting very noisy.
On both my D2's I've had to disconnect power to it as the noise got excessive, BUT the heating still works though takes a little longer to warm up in the cabin. However, the main point of this is that the pump also drives the circuit for the "Rest" heating function, which I have never ever found a use for. BUT it's worth testing - get the engine warm, turn off ignition and then try the Rest heater. The HVAC should start up; see if it's warm or cold in that scenario. As noted above, it's a bit of a mission to change the unit (and expensive) so you do need to be sure that's absolutely necessary.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 30th April 2014 at 09:47 PM. |
