For Sale and Wanted - General Posting for buying / selling your own personal non vehicle related items |
Cheers - will check the seals (no access to ETKA)
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() |
The black module is the EPB controller, can't see the part number on the other one.
IIRC mine only has one ECU there, the EPB one. Perhaps the other boxes are related to the TPM module (assuming the car has TPM).
It does have TPM.
Hi Andy
I'm at office so can't see the pictures, but I will say what others said already. DON'T do it yet, especially if you would be out of pocket by a lot of money. This is more likely related to that water leak, all your problems. In this cars one thing can affect other modules even if they are not really related, its just all complicated electronics. Isn't there a battery management module as well?? Just strip that side out completely, get everything out and look for a leak, even run a hose and you may see water coming (with all the bits out already so you dont cause more damage) Even if some modules are water damaged they will still be repairable without any cost to you. I've repaired over the years many electronics, all sort of ones damaged by water, and if you do it right chances are pretty big. Unless its burned out completely, but if only one or two components then its not a big issue. Don't do it yet, you just haven't found the source yet but at least you've got indication where to look.
Doing my head in
![]() Washed the car and before hand removed the battery so I could check for any leakages. Found condensation in the compartment - hope this picture shows it (on the cable): ![]() Nothing came in via the back lights etc (Boot floor totally dry) Picture of the area that was wet - as pointed out below the battery is an area with 2 modules (Windscreen Heater and Electronic Parking Brake) but to the right (rear in the pic) are holes and the bulk of the water is in this area: ![]() Anyway - after doing this - put the battery back and before hooking it I checked the voltage and it showed 12.5V Got in the car and nothing - tried a few times and nowt! CHecked the voltage and 8.5V ![]() Put my other battery in and all good - just want rid now ![]()
OK.
Now we need to find where the water comes from Shame you didn't what I suggested earlier, leave the boot open, stick the hose on the roof so the water runs down the rear screen but no excessively so it dont go straight into boot of course, or something like that, and watch for any running water there where you found it today. Is it possible guys that water gets somehow behind the rear screen and runs down straight into the boot but somewhere on the side panel side??? How about the boot seal, I assume you looked at this properly and if that would be the seal then you will find water inside the actual boot as well. Condensation on the positive wire would indicate that water is getting through the top??? Now, you have two unit there, I assume there is no faults in the VCDS on those two units?? If they would be slightly water damaged they could drain the battery. Above the batter where the (-) is there is I believe battery management module, if condensation gets as high as the positive wire then it would get there as well. If there is any water damage to it that could drain the battery. Well, any water damaged module could be responsible for battery drain. Did you try to lift the rear seat and see if there is any sign of water or dampness??? How about the seal around the fuel cap, which is just about there, but from the inside??? This would kind make sense as its VERY close to where you found water today. This actually could be it.
I think it could be from the fuel filler - my car is LPG and that is where the extra filler is (pop riveted in) so I assume that water could be getting in through there??
I did run water over the rear window (gave the rear end of the car a very thorough dosing) and nothing. The condensation on the wire - I think is caused by the water just getting warm and evaporating not so much the leak (if you no what I mean) If I was to sell as is - what should I expect then?
Water should not come in through the fuel filler as that runs under the wheel arch..
I think its more likely your rear sun roof drains the pipe runs through the headlining all the way back to the rear arch but if the connection in the pipe brakes ie.. from using an air line ect to clear the drains then the water may just come through onto the rear headlining but also can run through to the boot in my case I caught it just in time really. |
Will have a look tomorrow and see if I can tell if it is that. Where should the rear drains end ?
