Old 10th May 2014, 04:05 PM
Presumably someone had been in there doing some work and not pushed it back on properly. (
Or maybe not........
I took off the handgrip and plastic casing and could then see better down into the space. The switch was actually broken so the plugs were connected.
Unfortunately the break is right through and close to where the wiring plugs fit on, so they are now waving around connected to a broken component with exposed conductors which could potentially short out on nearby metal components.
Probably not a major issue as it would at worst turn the warning light on - or would that have other effects if detected by an ECU?
The wiring doesn't seem to have much slack on it but I'll try fishing it out to remove the exposed broken bits of the switch.
One thing is certain, replacing it is a major job.
Old 10th May 2014, 04:36 PM
Got it!
No idea how this fixes to the main part of the switch though.
Old 10th May 2014, 08:56 PM
You seem to be having fun with this issue and all the posting. Just thought I would respond to assure you that someone is reading the posts!
I also have a bodged lever trim. I keep meaning to look at a proper solution as it does seem a common failing.
Old 11th May 2014, 08:31 AM
Thanks, I actually got some really helpful answers early on but being a persistent type decided to investigate further despite the job appearing too daunting.
Also, I absolutely hate it when you see a forum thread (not here though, or very rarely) where after a selection of constructive answers there is no further response from the questioner. Or worse just a "thanks, all OK now" with no indication of how they actually solved the problem.
If I offer some advice I like to know (constructively) whether it was helpful or another option was actually better, and why.
Old 11th May 2014, 09:28 AM
I've attached some pics of the brand new handbrake trim I've got here so you can compare and see if there's bits missing or not
ID:	8032   Click image for larger version
ID:	8033   Click image for larger version
Old 11th May 2014, 09:43 AM
Thanks Adrian, nothing missing, just extra duct tape "padding" inside the "cup" of that strange downwards protruberance at the front end that gets gripped using the pinch bolt.
As noted, I'm going to "improve" mine by adding a thin piece of rubber instead.
Edit: Done. While I was at it I noticed that the front 2" or so of the lacquered top had been badly scratched by the underside of the drivers armrest.
Brasso, then Silvo and finally furniture polish and it's as good as new. OCD strikes again.
