Old 10th May 2014, 06:31 PM
The auto lock is speed dependent and engages once the set speed is reached.
You ought to do some digging into the boot locking with keys inside as it shouldn't do it.
My cars the same year as yours and when I left the keys in the boot it opened straight away and I tried numerous times to close the boot for it to only open again until I realised that the keys were in the boot.
I also today left the keys in my jacket on the passenger seat and tried to lock it on the button on the door handle and it refused to lock.
Try locking one set of keys in various places in the car while you have the other set handy and then swap keys and do the same again to see if both keys behave the same.
Could be a weak key battery or possible a defective antenna in the boot
Old 10th May 2014, 06:53 PM
Norretal's Avatar
Norretal Norretal is offline
Thanks Del, I've read about the various problems a weak battery in the key can cause and the more I'm hearing from others I suspect it shouldn't have happened. I'll have a good look through the manual tomorrow and see what I can find.
Audi TT - 2015 - Ultra
Old 4th June 2014, 09:00 PM
MAM MAM is offline
If I use the boot close button, mine also re-opens if I leave the keys in the boot. I have not tried it without using the button however.
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
Old 4th June 2014, 09:51 PM
Still does it.. been there, done that
