Old 14th May 2014, 09:27 AM
Somerandomguy's Avatar
The picture above is with the boot closed, and this one is when it is open, sorry I am on my ipad, so editing is a bit hit and miss...
Old 14th May 2014, 09:30 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Interesting.
My striker plate is in the down position and does not move.
Looking at your images the cable that pulls it down goes to the right hand side of the boot.
I wonder if I knocked something off when I was fiddling around with my bumper guide.
EDIT: Your motor seems so quiet in relation to mine as well.
[center]
06 3.0TDI Quattro:
Options:
Old 14th May 2014, 10:29 AM
Brilliant info. thanks, gives me the confidence to tackle this long-standing problem.
Old 14th May 2014, 06:01 PM
thanks for that
ive had this problem for some time, if i close it hard manually it locks, knew it was something in the mechanism just havent got time to do anything with it
Old 14th May 2014, 06:25 PM
ScottD3's Avatar
Two hours later, 2 battery removals and refit plus some time on VCDS and I found the issue.
Two snapped teeth on a cog.
No idea when or why this happened.
Part of my thinks it was when I plugged or unplug the cables and it confused the motor, it spun up and snapped the teeth.
At least I found the issue, I just need to get it fixed.
I doubt I can buy the needed cog so it's back to A8 Parts and see of they got a motor.
[center]
06 3.0TDI Quattro:
Options:
Old 14th May 2014, 06:38 PM
Good job Scott, shame it's that not a spring or something simple
By the way, great info Random Guy
Old 14th May 2014, 09:25 PM
Grrr. If this was 2020, you would just 3D print a new one using a solidworks file you downloaded from a solidwork sharing site.
