Ladies and Gents,
On the ongoing OCD search for perfection with the D3 I have noticed that there is a "Crackle" coming from the front dash speaker. Done some work into this and I think it may be the amp but would welcome any feedback if anyone has had any experience with this in the past. Points to note: 1) CD and Radio both crackle 2) No matter what the music source it crackles 3) This is not cooked or rubbing voice coils on speakers 4) There is no intermittent sounds or breakup 5) Volume and power all OK and no distortion 6) This does not sound like driver distortion The crackle to me sounds like its not being processed correctly or perhaps an Amp being a little upset hence why I am thinking Bose |
Have you tried fiddling the Bose sound settings?
Not touched them, its a valid point as the processing could be the problem.
I shall have a play and see, plus ensure "Crackle" is turned off ![]() |
IIRC Ian had some problems with the centre speaker, its dead easy to replace it and that would be where I would start. Replacement speaker should be easy to source from a8parts.
http://forum.a8parts.co.uk/showthread.php?t=6402
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 17th May 2014 at 07:02 PM. |
Thanks but this is not speaker rattle or distortion here, it's electrical amplification or processing.
I may take out the amp and check the boards. |
On other makes of car with BOSE, I have read on forums several times this attributed to dry joints within the DSP/amp.
Agreed, that's my thinking on this now also after some Google homework.
May have a look over the bank holiday weekend! |
