Old 22nd May 2014, 04:34 PM
It's always as you sit in the car.
^^^^ wot he says.
Left and right is always from the perspective of being sat in the car, facing forward, never looking at the car from the front.
Old 22nd May 2014, 06:49 PM
I stand corrected
The diagrams in elsawin never seem to make it clear if the part is drive side dependent
Old 24th May 2014, 06:02 AM
bobbygd bobbygd is offline
I had the same problem with the up/down warning light, this can be caused by a faulty leveling sensor
I was told by my dealer that they can check the code once the "up/down" light is on the dash,
When i had mine checked it turned out to be the rear leveling sensor at fault causing the lights not to level, when the car was stationary the xenon lights would make a lot of noise like a stuck motor and move up and down trying to level,
New rear sensor fitted and all ok
affiliate marketing programs
Old 26th May 2014, 08:53 AM
Well, as Ian said, it's on the driver's side.
But it's not part number 4Z7-907-357 (which is what I bought!), it's 4AO 907 445 A.
B****r!
EDIT: On ebay this part number is listed as a WING / DOOR MIRROR MEMORY MODULE 4A0 907 445 A
Off to look on the passenger side.....
Old 26th May 2014, 09:05 AM
Looks like Ian might be wearing his hair shirt along with sackcloth and ashes later......
Old 26th May 2014, 11:11 AM
Yes, it's on the passenger side!
Swapped the unit, but warning light still on. Does that have to be cleared on VagCom?
Old 26th May 2014, 11:22 AM
Have you been for a drive with the lights on?
Old 26th May 2014, 11:42 AM
I think you need to clear the fault Jim
Old 26th May 2014, 12:00 PM
I'll come around this pm and do it if you want?
Old 26th May 2014, 01:46 PM
No, not been out with lights on.
Yes, David, that'd be great. Anytime that suits you
