Old 27th May 2014, 08:01 AM
That's sounds like your at your wits end, feel for you.
It was my understanding from reading about someone else's car with multitronic that the module you mention is attached to the gearbox and not inside the car, if thats is true then the gearbox fault should be unfortunate but not related.
Unless the scuttle drains are leaking down over the gearbox ecu, but like I said I don't know about the multitronics so don't know where the ecu is on the gearbox or where it is in relation to sources of water.
I remember reading on a forum somewhere that the multitronic ecu has a weak point on a connector inside the case that goes intermittent like a dry solder joint, and can be repaired reasonably easy if you have the tools and soldering skills, I think that's what the chaps on eBay are offering when the repair your ecu.
If I can find the forum I will post a link
Might be worthwhile checking the harness to the gearbox too before you go further and spend lots of money.
I hope you get it sorted out.
Found this site, it shows what I was talking about, on the a4 multitronic ecu picture with the broken wire.
http://multitronic-box.com/tag/gearbox-ecu
Old 27th May 2014, 12:30 PM
I would assume the gearbox ECU is located 'wet' inside the gearbox if it's the same as other multichronic boxes. These guys should be able to resolve the fault if it is circuitry based and return the same unit to you - obviously it requires another garage to remove the box and fish the unit out! Given they're due oil changes every 40k if memory serves I would hope it's been done, if not then the clutch pack will probably be past its best.
http://www.bba-reman.com/UK/
I would stay away from the main dealer and find a local specialist who will be more familiar with slightly more senior aged cars and more inclined to fault find than to throw new parts at it in hope!
I suspect as Delboy has said you may have more than 1 fault lurking. The F125 switch is external on the box (at least it is on the ZF box) so that could be causing some of the issues - it will light all the gear selector lights for a start. I suspect the interlock preventing you starting the car in anything other than park or neutral is what's stopping it turning over, so that's by design rather than a symptom. These may be entirely unrelated to the water ingress, but it depends if it's got into any electrics elsewhere and is causing the short
Old 28th May 2014, 06:33 AM
A8 Adie A8 Adie is offline
Hi Guys
Thanks for your responses. Yes the TCU (J217) is externally attached to the top/rear of the gearbox and looks like the left hand photo at http://www.ecutesting.com/vw_and_aud...arbox_ecu.html
This module includes, among other components, the multifunction switch - F125, and yes you've guessed it you cannot buy this separately.
These are the guys that quoted me the c£250.00, and with 2 years warranty is probably a better deal than a new one from Audi.
It could be co-incidental that this all kicked off at the same time as the water ingress issue, but take I take your advice about inspecting the wiring harness, before spending big bucks.
It is clear that the start authorisation module is getting unclear signals and is (correctly) blocking the engine start.
Later today I will get the diagnostic report and recommendation from Audi, then I will decide what course of action to take. I have located an independent Audi Specialist about 5 miles from me. It seems likely that I will be giving them a visit tomorrow.
On top of all this I have just remembered that the MOT is due on June 2nd.
I will keep you updated as things progress
Old 28th May 2014, 07:52 AM
Architex_mA8tey Architex_mA8tey is online now
welcome along Adie
Glad to see you can finally post!
Old 24th June 2014, 09:02 AM
Default Nothing to do with water as it turns out!
After considering all my options, I decided to take the car to the Auto electrical garage and asked them to carry out an MOT in preparation for possible sale (passed with 2 advisories). Whilst they had the car the fault went solid, as the guys from ECU testing (www.ecutesting.com) suggested it always does. So I had the TCU removed, which requires the gearbox to be drained as it is wet as correctly suggested by Adrian E and sent it away for a rebuild. The unit was returned within 5 working days as promised and refitted to the car. I have had the car back for 10 days now and it has started OK 4/5 times each day, but I was still V. cautious of washing it. The laws of nature helped me here as we had a rainstorm of biblical proportions yesterday afternoon (only thing missing was animals appearing in pairs). The car still starts OK.
Total bill for MOT; Service and repair £780.
Much happier now - will post a photo of the car once I have polished it.
Thanks again for your comments
