Indeed Scott if it were a relay slot from the car then it would be a bit permanent, it could easily made up with plugs like I said earlier but with a relay carrier so if the relay failed it could be easily swapped.
Spent some time last night looking at etka and elsa and think for the sake of speed and convenience the mid will be best placed I'm the battery compartment as that's where the central convenience unit is. Putting it there means larger plugs with more wires but like I said they are cheap. I'll keep you posted
Del ![]() |
Is there any relay holders near the battery?
The boot lid seems easier. More space to work and easier access to the plug. Unless I'm missing something?
Having worked in both areas I will go with battery compartment as there's no trim to remove.
If the mods plug and play the then it's a walk in the park
Del ![]() |
Due to recent work, I've had enough of that side of the car.
But you're right.
