Originally Posted by Goran
Ainarssems is right, +/- 0.3s is not very accurate. If you want accuracy best to look for a gps with sampling rate of 10 times per second, then accuracy should be +/- 0.1s
But, its good fun to be able to use VCDS, who wants to throw away £400 on a Performance box meter or similar.
http://www.seatcupra.net/forums/showthread.php?t=87905
the cheapest performance mod is to run with your fuel tank almost empty. If its a 90l capacity, you could drop around 60kg, which could improve your 0-60 by around 0.2s
OK, I get the point, but if anyone will do exactly same runs via VCDS then we all will have accuracy of +-0.3sec, and lets don't forget that this is just for fun
...and to shut Mr Dezzy
PS. Dezzy, if you decide to to the down hill run to improve time, you may actually attach the trailer to the front bumper as it will take you down hill even quicker than without it
