Old 16th June 2014, 04:56 PM
This is the build..
But my main problem is the abs module is off an A8 W12 and I used the W12 info to log in .. also loged in to basic setting 40168
And it still said coding rejected to re code it for the 4.2 ?
Old 16th June 2014, 05:23 PM
Hi David
Just very quickly as it's mental on my end.
Just to clarify
You've installed a ABS module from W12??
What info you have used from W12?? Coding is a combination of brake calipers etc on the car you fitting it (info on the sticker from your current car not donor), therefore you can't use the W12 coding as this has different components installed. As far as I'm aware. Someone correct me if I'm wrong.
Is a W12 module compatible with 4.2 at all?? This one I'm not sure.
And to clarify, yours is 4.2 petrol ??
Old 16th June 2014, 05:47 PM
Hi yes the W12 module is identical to the 4.2 its the coding that is different
The log in I used for the W12 module is 06137
Long wheel base
18" 1LJ
12 cyl
Auto
And the new coding needs to be
0007597 and that is
Long wheel base
17" 1LL
6/8CYL W/O BREMBO
AUTOMATIC
Old 18th June 2014, 07:23 PM
any ideas anyone ??
Old 18th June 2014, 07:45 PM
Hello mate
My apologies, I completely forgot. That day I did mentioned that I'm busy as hell, but yesterday I just forgot as I've had all evening to my self so I was in shock.
I'm doing it as we speak.
5min
Old 18th June 2014, 07:47 PM
OK, this is my understanding.
(you did follow the whole procedure as per Ross-Tech clip just in case??)
I wouldn't use the login for the donor car, but current car.
Have you tried this login:
06297
And then coding is correct:
0007597
Old 20th June 2014, 07:29 AM
It would not let me log in using my current car log in ? It seems to only accept the log in of the donor car ? ....
Old 20th June 2014, 08:31 AM
Hi David
Hi Marcin
I know his forum name might suggest his real name is David, but it's Guy! As in the number plate!
But I'm sure he'll not mind what you call him with the all the help you're giving!
