VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
any ideas anyone ??
Hello mate
My apologies, I completely forgot. That day I did mentioned that I'm busy as hell, but yesterday I just forgot as I've had all evening to my self so I was in shock. I'm doing it as we speak. 5min
OK, this is my understanding.
(you did follow the whole procedure as per Ross-Tech clip just in case??) I wouldn't use the login for the donor car, but current car. Have you tried this login: 06297 And then coding is correct: 0007597
It would not let me log in using my current car log in ? It seems to only accept the log in of the donor car ? ....
Compatibility issue as mentioned before?? Could you post the year of your car and part number of the module you've fitted and I will check if it's compatible with your car. LWB A8 4.2 Petrol it's all I know so just the year and that should be enough. Do you know if the part number of the donor's module is exactly same as the one from your car?? PS. Cheers Jim for clarifying Guy's/David's name ![]()
Ok yes its a 2003 D3 .. and hear is a whole host od modules I can get hold of .. il have to go and pick the correct one from london.
This first one is the module I removed first ![]() ![]() The rest are what they have in stock .... ![]() ![]() ![]() ![]() the one I fitted ended in H44 ...and lets me log in as a W12 but will only accept and store W12 settings ... and all I get is a dash board like a xmas tree foolishly I did not take a photo of the part I fitted I just assumed it would work... ps im very very very grateful for all the help im at a loose end with this |
No problemo guy
![]() I'm sure we will get to the bottom of this. I'm going out now for about 2-3 hours and will jump on it as soon I'm back. Are you far from London? Are they not prepared to ship it to you?? If not where are they Base coz if close to me I could pick it up and ship it over to you via ups next day??
From your picture am I correct in saying that a BD should work fine is that 8 cylinder + diesel too ?
