Old 21st June 2014, 06:24 PM
CC - 4.2 petrol A8
http://www.shopdealerparts.com/volks...en/4e0614517cc
Old 21st June 2014, 06:30 PM
There is a CH as well as CC for 4.2 petrol (LWB)
Old 21st June 2014, 06:35 PM
Now, correct me IF I'm wrong, but 4E0 614 517 C or CC is your part number
Photo 1 of 4
Old 22nd June 2014, 07:32 PM
Ok well I have just got home .. I now have a BD BB E ...
So I have 3 to try .. will a BD OR BB Work do you think ? ....
Old 22nd June 2014, 07:35 PM
I also have one from a VW phaton Long wheel base .. 4.2
The connection is the same but different part numbers
Old 23rd June 2014, 10:00 AM
Hello Guy, sorry for the late one.
BD was originally dropped and replaced with BG which was again dropped later on and replaced with CF which isn't a compatible part number with your car.
BB was dropped and replaced with BE and then again replaced with CG which isn't your part number.
E was originally replaced with L, then again with C and C was replaced with CC which is exactly the part number I mentioned couple of days ago and it is your part number.
Go straight with 4E0 614 517 E
As per picture below, you can use any of the following, C, E, L, A and CC (latest PN)
Old 23rd June 2014, 05:04 PM
Bugger ! I dont have the E ! I have BB AND BD !
Old 23rd June 2014, 05:31 PM
http://www.ebay.co.uk/itm/AUDI-A8-D3...item3ce2ca14c3
You said you have BD BB and E
Link above is a C which is fine, same as E L A CC (as mentioned above)
Don't worry, you are almost there mate
All you need now is the correct part and you'll be laughing
Old 23rd June 2014, 06:26 PM
Ok so the BD ..plugged in now displays as a C not a BD...
But it dose say BD top line and C bottom line ... just cant log in because I have to guess what car it is
Yes sorry no idea where E came from I dont have that at all
Old 23rd June 2014, 06:30 PM
Did we say a C works and was later replaced by the CC
