D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus |
Hi chaps old thread but I have noticed the same on mine, Bose system vibration on the rear shelf didn't have this in the d3 you could wind that up full and nothing rattled!
I sat in the back today and placed my hand on the shelf when it occurs and it stopped so I guess it's the shelf not the speakers. Certain frequencies seem to set it off on certain tunes. Did anyone get this fixed before I tackle the local Audi boys? I looked underneath but it's all covered so needs striping to get assess. Also noticed there's a movement in the drivers seat ....like the seat is slightly loose on its fixings. I have read on another form this is a fairly simple if involving a fibre washer .... Again anyone noticed this ? Other than that the car is faultless and a really nice bit of kit, mpg is astonishing for such a large motor and so quiet and comfortable. I have had to to set the speed alert ![]() Cheers Glyn
Previous 8's Audi A8 V8T Sport Exec. ![]() A8 3 litre sport till 2016 Short walk on the MB dark side ![]() A8 3 litre sport from 2010 to 2012 |
Not had the driver's seat issue, but I'm on 35K now, so maybe something for later. |
Try this Audio CD rip..
http://tpbproxy.cremoznik.si/torrent..._(Bass_Mekanik) GET THIS TORRENT and see what frequency it does it at on the bass sweeps, then you can put on track repeat and try prodding and poking until it stops. You need to download an app called UTorrent before you click the links above. Last edited by snapdragon; 10th August 2014 at 11:14 AM. |
Revival of an old thread. My D4 developed a buzzing (farty) noise from the rear central subwoofer. Removal of the grille revealed the speaker central dome was coming adrift and vibrating at certain frequencies. I bought a used speaker unit from Prestige (great service as usual) and today attempted to change them out. We took the upper boot trim out with a view to bring it out that way but there was no way that could be done. To take it out would entail removing the parcel shelf which appears to be a massive job. We decided to try dribbling flexible super-glue around the rim of the dome.It appears to have worked. We'll see if it lasts. I have the replacement if push comes to shove. Fingers crossed. Hoping this may help someone in the future.
2010 D4 SE Executive 4.2 TDI |
