From memory my h&r spacers have a taper seat and the bolts supplied match that taper as you'd expect. They do have quite a small depth so the spacer bolts sit within the thickness available so regular wheel bolts would be no use
I posted info somewhere here on ordering a set at a good price from euro car parts using discount codes from AudiSRS and quoting a part number I found on Amazon
Ref spacer size - I think 20mm is the smallest non-bolt through spacer you can get. They do space the wheel right to the arch line but mine has never rubbed even fully laden. Maybe slightly thinner would be ok but not sure I like the idea of 15+mm extra length on wheel bolts tbh
