Old 9th May 2014, 10:53 AM
Sir WIll Sir WIll is offline
Yes had a couple of clips missing and the odd wrong screw so replaced all of those when I was in there!
Old 14th June 2014, 06:02 PM
sparksuk's Avatar
sparksuk sparksuk is offline
Does it really work with solder flux paste ? What is the trick with that ?
Old 14th June 2014, 06:05 PM
sparksuk's Avatar
I have replaced the gas struts, but i have the same problem. I have oppened the motor, i put some more grease on the gears, but no solder paste. Still doesn't work properly. I was thinking to replace the hinge too.
Any other ideas ? Apart from replacing the whole motor 😄
Old 15th June 2014, 10:22 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I greased all my hinges up about a month ago and my boot is working better.
not 100% of the time, more like 90%.
A new motor is the only sure fire way I think.
[center]
06 3.0TDI Quattro:
Options:
Old 16th July 2014, 10:19 AM
audifin audifin is offline
Originally Posted by audifin View Post
Replying this old thread:I was able to fix mine with solder flux paste following instructions from these youtube links:
https://www.youtube.com/watch?v=-G-OedMyf8o
https://www.youtube.com/watch?v=PG1v9xDpDH4
Basically if the motor is spinning but the boot lid is not moving then the clutch inside the motor is slipping. You can fix that by applying some solder flux paste on the clutch. Try applying as thinly as you can, I put too much first and had to disassemble the motor again because the clutch got totally stuck Anyway it works like a charm now and the total cost was £1.70, so I'm well happy
A little update: The solder paste works for a while, but then melts away, especially in this hot weather!!
However, found this link on google and decided to try it: http://www.dognmonkey.com/audi/how-t...-audi-a8l.html
Bought "Violin Rosin" off eBay for £1.69 delivered, scraped it with a knife into dust/crystals. Cleaned all the old soldering paste off the clutch and replaced it with small amount of this "dust", and it worked perfectly first time. Time will tell how long it will last, but I have gut feeling it will last much longer than the soldering paste.
