Old 25th July 2014, 12:51 PM
The two air compressor ones should both be fixed by the kit Andy supplies.
Would not worry about the battery one, it just means the battery level dropped and the car shut something off to save power. I get these all the time at varying stages but the car is always fine.
Old 28th July 2014, 08:08 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I rebuild the suspension pump over the week and went for a drive.
I'll scan it again tonight and see if anything has popped back up.
[center]
06 3.0TDI Quattro:
Options:
Old 28th July 2014, 02:09 PM
The g291 fault is because of low pressure and the over temp because its been running too long and overheating because its not able to get up to pressure but since you already rebuilt it then that might be ok now.
The battery regulator has dropped into first stage possibly when you have been messing about in the car with electrics on and no engine running, stage one is nothing to worry about if you scan and see it go through all the stages 1-5 in quick succession then that would most likely show a knackered battery.
The mech failure, don't know, possibly a flap motor???
Old 29th July 2014, 05:00 PM
Whilst I was in my car today scanning the engine and HVAC ECU due to other issues, thought I'd check the level control module. Result, no faults showing since the Andy kit was installed in January.
Old 30th July 2014, 12:21 PM
ScottD3's Avatar
All the above fault codes are now gone and not returned.
WooHoo.
Apart from the normal ones.
[center]
06 3.0TDI Quattro:
Options:
