Old 2nd August 2014, 11:09 AM
RNS-D is canbus, but not Audi Canbus to make life more interesting.
RNS-C looks very similar, but was pre canbus and might work better.
I'd expect issues such as power not coming on/off with ignition, lighting etc not to work. Otherwise, it will operated fairly well as long as you supply it with power, ground etc.
I dont believe there was ever an OEM method for getting digital on the RND-D. There was a box for the RNS-E, but I dont beleive it is compatible (different canbus' wont help)
speak to a8parts, the sponsors of this forum. They may be able to supply the wiring from the headunit to the TV tuner. There were 2 types of tuner with very different connectors. without this, its going to be a faff to wire up.
Only kufatec have ever shown a product that can get digital TV on an RNS-D to my knowledge, so I cant help with any cable thats gonna connect all those bits together for you.
Aerials again will depend on the type of TV tuner you've got. But at this point I'm not convinced its compatible with your head unit anyway....
Everything on the D3 is tightly canbus integrated. You're either highly gifted and like a challenge, or have no idea what can of worms you're opening here.
If it were me, I'd junk eveything you bought and run with an RNS-E and stock digital tuner instead. The bluetooth module on that is very good and all will stitch together nicely...
