Old 7th August 2014, 11:47 AM
rory_pamphilon's Avatar
rory_pamphilon rory_pamphilon is offline
Sorry to dig up an old thread, I too recently was working on my sunroof drains after a deluge landed on my gf as she sat in the passanger seat on quite possibly the single worst occasion it could have happened.. in labour on the way to hospital for our first baby
So I parked the a8 facing down on a very slight incline and opened sunroof and poured 2 liters of water in either side of the sunroof tray and the front ones appear fine. I then parked the car facing slightly uphill and did the same with the rear, it appears the drivers side rear drain is fine but the passenger side rear was blocked. This explains why a sudden deluge of water poured onto my gf the first time I used my brakes after parking on a slight upward incline over a wet night.
Anyway can somebody explain a good method for cleaning out the rear drains, I used strimmer cord pushed through the front ones but its impossible to reach the rear drains from the top. I found the drain when looking behind the cd player in rear quater and tried pushing cord back up it but it wont budge, some serious crud stuck in there somewhere. Any ideas how to get it out??
thanks
Old 7th August 2014, 02:15 PM
Have you got access to a compressed air line? Maybe at a friendly local garage?
Old 13th August 2014, 11:29 AM
I dont have easy access to be honest, I can try and ask nicely at a local garage though and see how far I get.
Would a can of compressed air do instead maybe? Theres definately something quite solid wedged in the drain somewhere, zero water comes through when sunroof tray is full of water. Maybe some heavy power cable pushed up from boot end may do the trick also.
Will let you know how I get on
