Old 1st November 2009, 03:46 PM
They're erm.. what's the word..
Oh yes.. Wrong.
If you have the latest MMI (5150 or 5570) then you can drop MMI in (I think it needed 3120 as a minimum).
You have 2 options.
1 - Easiest - Just replace the CD Changer with the AMI unit. Keep the CD Changer so you can perform updates if any ever come along (what I did)
2 - Bit more fiddly, but not too bad - Keep both and replace the pigeon hole in the glovebox beside the CD changer with the AMI. Needs soem new wiring/fibre components and the MMI told that it has another media unit, but still perfectly doable.
Old 3rd November 2009, 02:35 PM
A8 Doc A8 Doc is offline
What he said
I had AMI in my 03 plate 4.2 Quattro.
Old 4th November 2009, 09:49 AM
CBA_caption CBA_caption is offline
Thanks chaps,
I'll have at them. Normally had a very good relationship with my Audi dealer. Was very surprised with their original answer and your replies confirm it! They gave me some banter about hardware not being compatible, but I can't see them going back from '03 to '06.
Now then, I know this is probably water off a ducks back for you, but is this a job an "Audi specialist" would be able to do or is is best to go to the dealers?
Fiddling with the fibre network sounds like a shortcut to a broken car! Unless it's simply a matter of plugging sockets in.
Thanks again for your help,
CBA
Old 4th November 2009, 05:24 PM
Mostly a matter of just plugging cables in..
Depending on where you are in the country, Craigy @ tclsatnav.com is a good guy to go to as Audi can be really funny about it.
If you just want to do the swap out (as I did), then Kufatec.de sell the unit on its own.
Old 6th November 2009, 04:55 PM
Thanks again for your help.
Tempted by AMI and DAB radio now!
CBA
