Old 25th August 2014, 08:50 PM
Conquistador's Avatar
Mine had exactly the same! If you press it, the MMI screen cycles between a few input channels. It just means that your car has TV/Freeview pre-wiring. If you do get Freeview fitted, it would work by pressing this button to cycle between the Freeview and back to the MMI, I believe Pete said!
I used to keep an LED torch in that compartment and accidentally knocked the button once and panicked thinking I'd broken the MMI system somehow.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
