Old 25th August 2014, 08:57 PM
harrybosche harrybosche is offline
Default Offers for my fl s8
Due to overseas contract work I am making a decision to sell my S8.
Definitely not an easy decision and one that I will surely regret in the future.
It's been a daily driver for my motorway commute for the past two and half years and I have never enjoyed driving 57,000 miles more than I have in this car, however, I don't want to dwell on how much I am going to miss it. I just need the opinions of the knowledgeable Forum to arrive at a fair sale price!
VEHICLE DETAILS;
2001 S8 Fern Green, leather/alcantara, heated front seats, registered as alternative fuel car with certificated BRC LPG system fitted Feb 12-wheelwell tank will take 70+ltr giving 300 mile range on a run. Private plate not included. 12 month tax, MOT until Oct but will MOT prior to any sale, 152,000miles.
Work carried out over the past two and half years includes;
Replacement of :-
Fuel Tank/Fuel Pump Aug 14
Crank position sensor Aug 14
Air Mass meter Jun 14
Front lower suspension arms Jun 14
NSF top suspension arm/hub assembly Oct 13
Brake Disks/pads plus rear calipers Oct 13
A/C condenser Jun 13
Timing belt kit, water pump and T/stat (127k) Jun 13
PCV Valve Aug 13
O/S/F wheel bearing Mar 13
ABS modulator pressure sensor Dec 12
Gear box rear oil seal Mar 12
Gear box oil changed @ 124k & 146k
Spark plugs (NGK LPG-1) Oct 13
Tyres replaced Dec 13
As everybody knows you need deep pockets to run these fabulous cars and obviously all receipts are available. On the negative I have been meaning to get the wheels refurbished and the engine uses oil. Approx 1 ltr per 600 miles.
However, I found this to be the case shortly after I bought the car and it hasn't really changed, I found it easy to live with. Emissions are all ok and engine is rock steady at idle and as smooth as you would expect. I was given some spares and old receipts by the previous owner and found that that included a set of valve stem seals
Hopefully a set of pictures will accompany this post!
Name:	2013-04-18 19.36.34.jpg
ID:	8845   Click image for larger version
Name:	2013-04-18 19.36.45.jpg
ID:	8846   Click image for larger version
Name:	2013-04-18 19.37.55.jpg
ID:	8847   Click image for larger version
Name:	2013-04-16 16.58.27.jpg
ID:	8848   Click image for larger version
Name:	2013-04-18 16.40.14.jpg
ID:	8849   Click image for larger version
ID:	8850   Click image for larger version
ID:	8851   Click image for larger version
ID:	8852   Click image for larger version
