28th August 2014, 07:56 PM
The only thing I remember about it is from Audipages, apparently it will only go back in one way.
"To install: the bottom of the cooler must go in first and THEN tip the top part in. Trust me, it will not go in any other way. The pic below is the "HOW NOT TO" reference."
http://www.audipages.com/Tech_Articl...reinstall.html
and this:
The unit will go back into the car without jacking on the engine block with loosened motor mounts or any other shennanigans, but it will only go in one right way and there are many wrong ways to try. Hard to describe, but if you are under the car and get stuck, read this and you will see what I mean. If you get it into the space but the oil filter mount is tilted outward toward the frame rail, forget it, it is wrong, you will never get the filter housing to tilt down past the frame rail. Take it back out from below and try it with the top of the unit tilted away from the block and the bottom close to it. You may have to rotate it a little, but it will go in this way so un-freakin-believably easy that you will want to dance a jig. Both during removal and reinstallation, be mindful not to bash the fairly fragile matrix against the engine block. It would really suck if this thing sprung a leak.
