Old 4th September 2014, 06:11 PM
If MMI reset won't help then it is more likely locked by Audi from new and disk inside was never changed.
They think this will stop us from ''doing things'' ,
Then you will need VCDS unfortunately, its literally 10sec job, plus another 10sec to change the settings to drive being unlocked at all times
Old 4th September 2014, 07:20 PM
Greg66 Greg66 is offline
Tried the reboot with no success. Thought I had bagged VCDS on eBay but the seller has since decided to cancel the transaction! Trying to find out WTF is going on...
Old 4th September 2014, 07:35 PM
Is there really a point getting off eBay, they sell almost for the same price what new ones from Gendan (£263)
And no matter how you look at it, you will get your money back within first 2-3 times you use it base on Audi charges.
And it looks like VCDS is your only option now
Old 5th September 2014, 06:31 AM
You need vagcom to unlock, but i have also seen times when this doesnt seem to work. However, you can also force an eject via vagcom which will net you the desired result....
