Old 9th September 2014, 04:09 PM
That's interesting - I bought new lower handle shells to match the wood trims I bought for mine. I could only get 3 out of 4 as they had no stock for the driver's door. The finish, which I presume is as old as the car as it's doubtful they made newer stocks post-production ending, isn't great and 2 are marked already despite me only doing about 4k miles since they were fitted!
I think the finish goes soft with age?
I went as far as talking to an interior trimmer who said he could refinish them, but wouldn't be surprised if they looked rubbish again after 6 months. In retrospect that's probably no worse than buying new, but would've been cheaper! Don't think he got as far as quoting me but got the impression it wouldn't be ridiculous.
Defo interested in the refinishing paint if they can do it
Old 11th September 2014, 03:54 PM
Mikey-S Mikey-S is offline
Well my friend at TPS tried his best. Audi say the parts are obsolete, and they don't supply 'repair paint' in any form.
I think my next step is to maybe get some paint or plasti-dip colour matched. I used a satin black paint on one of my S4's, on the interior grab handles and gear lever surround and you simply couldn't tell it had been painted, the match and finish was perfect. I'm hoping the colour match on the grey will be good or it'll really annoy me!
Old 11th September 2014, 04:13 PM
If you've got the part numbers try looking on Audi tradition site. My drivers door switch trim had to come from them. Postage is mental but it arrived and was BNIB as expected
Old 11th September 2014, 04:17 PM
I had a look on there last night. Couldn't see anything. I guess painting is the only option. If I could find wood trims with the exact same trim as the rest of the car then I would buy them, but the last thing I want is two different wood finishes.
Old 11th September 2014, 04:30 PM
You'd be surprised, it can actually be fine - mine is like that.
I had the horrible painted, sticky, peeling/scraped door switch panels and managed to get (from A8parts of course) some "wood" versions with the same colour painted areas, but actually a different (lighter) "wood" to the rest of the car.
It looks fine.
What made me think of accepting it was that my old PF S8 had a very different shade between the door switch panels and the rest of the car, nominally the same but practically quite different. That was apparently "normal" and to be fair I hadn't noticed for many years. There's an old thread here somewhere with pictures.
Edit. All in this thread, PF and FL and loads of assorted pictures: http://forum.a8parts.co.uk/showthread.php?t=5807
Old 11th September 2014, 06:44 PM
Some of those trims actually do look good. The amount of trim codes and options is huge, I guess getting the correct ones for my car won't be easy.
Old 11th September 2014, 07:10 PM
This thread and the one linked from it might help - the pics showing 2 different wood trims are actually matching trim code so would've been specced together from the factory.
http://forum.a8parts.co.uk/showthread.php?t=7038
The biggest challenge is finding the desired wood trims with the corresponding colour to the underside that matches your lower handle shells, which are only available in limited colours now.
I've attached pdfs of the Etka pages and highlighted the range of options, so using the colour code for your car you should be able to ID some options to look for.
I bought a set of 4 from A8 parts for about £100 if memory serves, but the drivers one was in a typical used condition and I decided to splash out for a new one.
Post some pics of your door cards if you want a 2nd opinion on options and whether you're IDing parts correctly
If you're after the dark grey trims like mine I have a driver's one spare if you wanted to try it to see if you liked the effect
