Old 9th September 2014, 05:26 PM
richardracer richardracer is offline
Default Emergency spare and MOT test
Hi folks,
I had my S8 MOT tested this week and failed first time because I had my spare fitted, which was 18" with same diameter tyre after a cracked rim resulted in flat tyre. Apparently the rules are wheels and tyres have to be identical across the same axle. Fitting 18" winter wheels solved problem. Retest within next working day at no further cost.
Lesson learned and hopefully knowledge passed on to this community.
Richardracer
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 9th September 2014, 05:31 PM
I'll check with my MOT tester mate, who passed both my S8 and Focus recently.
Was the spare a different diameter rim? If not what exactly was the mismatch?
Old 9th September 2014, 05:36 PM
This is a stupid rule! It means that folks with staggered wheels like mike and myself could end up with a refusal if we take our spare wheel along on the MOT test - I keep a spare that is actually 18" with 245 45 18 tyre on it in the boot at all times because I run summer and winter wheels that are either 21" or 20" respectively and the spare happens to be a rolling radius smack bang in between the two sizes so that it will work without causing a quattro fault . . . Geez!!
Old 9th September 2014, 05:43 PM
I don't think the MOT checks the spare (or not that precisely); this was on the car in use if you reread the post.
I have separate summer and winter spares.
Old 9th September 2014, 05:45 PM
Thanks for pointing that out Andrew - long day here!
Old 9th September 2014, 05:46 PM
It raises an interesting question Adrian - so does all that mean that the minute you put your space saver spare on the car it is no longer compliant with the MOT because the wheels on the same axle are not matching thereby voiding the MOT and the insurance?
Old 9th September 2014, 05:44 PM
The spare wheel isn't part of the MoT unless it's fitted to the car - there's loads of cars with staggered wheels from the factory (incl my parents Lexus IS and myriad BMWs)
What you must have across EACH axle is tyres of the same size and type of construction
Section 4.1 of the MOT testers manual 'Tyres (structure)' states reason for rejection:
One tyre is of a different nominal size or aspect ratio to any other on the same axle.
A temporary use or space saver wheel and tyre fitted as a road wheel
The only thing mentioned regarding spare wheels is under section 4.2 (road wheels) which states that 'the vehicle presenter should be informed if a defect is noticed on a spare wheel' but doesn't actually form part of the inspection to check it if it's buried away under the boot floor. You might notice a defect on a wheel slung underneath when checking components from under the car
