Old 9th September 2014, 10:23 PM
nigelw1982 nigelw1982 is offline
have cleared the fault codes and it returns even after a gentle responsible drive looking in elsawin it just says over revving and doesn't give any indication to weather it could be a crankshaft sensor or something similar. there is no abnormal engine noises sounds sweet as a nut gonna do a wet and dry compression test on the internals see is theres anything untoward going on but i don't think there will be bonn check all resistances injectors and crank and cam sensor connections try and rule out as much as i can change the fuel filter in case its being starved of fuel throttle body been stripped down cleaned and new gasket fitted and re coded to match i dont know weather its been remapped how would i check that and the will check the rev limiter after all internal test have been carried out
