all injectors are around 18 ohms stone cold engine tested outside not at room temperature all spark plugs checked all bosch super4's and of good condition, checked the hall sender 4.5v on pin 1 good earth on pin 3 0v on pin 2 should get battery voltage on that but will know more when i run some more test with VCDS. good resistance on the air injection supply 31 ohms, checked coils good earth on 4a 3.0 ohms on each of the coil packs
compression pressures 1= 110 psi 2= 120psi 3= 110psi 4= 120psi 5= 105psi 6= 100psi 7= 100psi 8= 100psi all these compressions were carried out on a stone cold engine not at min oil temperature of 30 degrees (what elsawin requires) or operating temperature dry of fuel as a problem with fuel line awaiting delivery of a new replacement. |
