Old 17th September 2014, 10:37 AM
I'd say you'd be better looking at custom cooling, more expensive, but you'll probably get much better results.
Old 17th September 2014, 11:14 AM
If you're thinking oem Look for kit designed for 'hot country' cars - they have uprated cooling systems to cope with the hot weather, but also have the benefit of improved cooling in cool climates.
The UK C5 RS6 Plus for example had the 'hot country' build code to give it more cooling to cope with the extra power....
Also consider looking at kit for the D2 W12, I'm sure its cooling would be superior.
Old 17th September 2014, 04:44 PM
andycaca andycaca is offline
first thing to consider, if you havent already, is a massive thermostatic oil cooler. turbo's cars really abuse the oil and it gets superheated.
my track car has nearly 500bhp and without a big oil cooler it does the same as yours...
Old 18th September 2014, 07:32 AM
RallyQuattro RallyQuattro is offline
RS6 oem water cooler is smaller than my S8 cooler and for RS6 hot climate then they have 2 extra small water coolers behind IC's.
I can't find any size on the w12 cooler? part no: 4D0121251AJ
I have a BIG oil cooler:
Cooling Row Quanity: 45.00
Depth (inch): 1.5
Height (inch): 13
Width (inch): 11.5
http://www.bmracing.com/products/702...k/?query=70274
Owns at the moment:
S8-97 biturbo = RS8 My new trackday car
A8-94, A8-96, A6 1.8tq -2004
2 Urquattro 20v-90 one red, one blue,
and one old Urquattro ex rallycar,
and some other cars..
Old 18th September 2014, 07:33 AM
Who can produce a custom cooler for me?
Owns at the moment:
Old 18th September 2014, 04:19 PM
thebluewhale's Avatar
Try these:
http://www.allisport.com/content/per...charge-coolers
Supposed to be very good at what they do and can make pretty much any size you need.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 19th September 2014, 07:53 AM
Originally Posted by thebluewhale View Post
Try these:
They respond to my e-mail directly
We can certainly make a radiator to your spec, however I would need to get hold of a drawing or pattern to copy to produce a new one.
If this is possible I would suggest using a 66mm core and a very rough price will be around £500+vat.
But I will check a local company first if they can make one for me.
Owns at the moment:
Old 18th September 2014, 08:30 AM
Depth (inch): 1.5
Height (inch): 13
Width (inch): 11.5
A8parts have one on the shelf, you could try asking them:
http://www.ebay.co.uk/itm/191136232719
Old 18th September 2014, 08:49 AM
But that one is 4D0 121 251 AG ?
And I found this measurements on AG
650*358*32
That is smaller than mine?
I have 720*440*43
Owns at the moment:
