Old 18th September 2014, 10:04 AM
Also, you have to double-pull on the internal handles to get out when the doors are locked .... isn't that a deadlock thing?
No. 1 pull unlocks it, 2nd pull opens the door. If it were deadlocks, then by definition you wouldnt be able to open it from the inside at all.....
From what you describe, its almost like the contact for 'unlock' is electrically not making it back to the central locking pump in the boot, which controls all this stuff.
As a wild, wild guess (As wiring is generally reliable) I wonder if anyone has ever replaced the CLP (which often fail) with slightly the wrong one, coded it incorrectly or somehow messed with the wiring plug?
Welcome by the way, always nice to see new enthusiasts who are able to articulate a well constructed post
Old 18th September 2014, 11:58 AM
I don't recall the exact pattern when I had trouble with the locking on my last 2002 S8, but it was pretty similar. I could lock on the key in the door but not unlock, and I could unlock the boot with the key, but not the rest of the car.
It turned out to be 2 faults: first, the central locking pump had an intermittent failure; and second, there was a mecahnical link in the driver's door that was disconnected.
The latter had clearly been the result of a previous owner fiddling about behind the door card and not reconnecting the link, but I'd never noticed because I'd never tried to unlock the door with the key.
BTW, an introduction and photos of your car are essential if you want the stream of advice to continue!
Old 18th September 2014, 12:13 PM
Ah, great thanks.
That further confirms it. Gotta be a mechanical linkage I reckon.
lol
I actually don't have many photos of it, but I will take some soon and post a proper intro. I've just spent over 3K on the car in fact, getting it back to showroom condition, so I think some photos are definitely required.
Here's one from a couple of years ago: http://i.imgur.com/2o2DSQ4.jpg
Old 15th October 2014, 12:01 PM
Thanks.
Identical, I'd say ...
... including the bit about not noticing the problem.
If it wasn't for the new key programming procedure, I would probably have never thought to try unlocking the door with a key until it was too late!
Good to know I can now get back in the car should the remote be inoperable, for whatever reason.
Old 15th October 2014, 02:21 PM
Yes, I was in Stranraer (south west Scotland) on a Sunday when my central locking pump failed and I discovered I couldn't get into the car at all!
Old 15th October 2014, 02:39 PM
Norretal's Avatar
Norretal Norretal is offline
Bit off topic but I went to access my D2 after it'd stood a few months, the battery was flat and the key fob wouldn't open the car. I'd owned it nearly nine years and had NEVER used the key in either the door lock or boot lock. A considerable amount of WD40 and a bit of patience gained me access to charge the battery, but it's the sort of problem I didn't think of until I had it to tackle.
Lesson learned, lube your locks
Audi TT - 2015 - Ultra
Old 15th October 2014, 03:36 PM
My boot lock was the same, which again I only discovered while I was investigating the driver's door lock issue. Couldn't even get the key in it at first, never mind turn it! It was like there was a key broken off inside; turns out it was just compacted road crud.
Lashings of lube did the trick for me too. I usually use this stuff though. Much better and longer lasting than WD40 I find.
Damn, that must've been somewhat annoying! How did you get back in (assuming you did, and the car's not still there of course!)?
Old 15th October 2014, 03:42 PM
Everyone probably has a favourite, this is mine: http://www.gt85.co.uk/
Old 18th September 2014, 12:06 PM
Ah, of course. Doh!
But that's the puzzling thing ...
From an electrical point of view, the central locking ECU is clearly seeing the unlock contacts close/open because, with the ignition on, it unlocks the doors (which, I must say, I find bizarre!) and, without the ignition on, moving the key to the unlock position, turns on all the interior lighting.
Why thank you kind sir .... I do try
I have actually posted here before ... about 4 years ago in fact, when I first purchased this car, but my user account was closed (probably due to lack of use). I've purchased countless parts from you too over the 10+ years I've owned my various '8s. Actually, I might be looking for a used, complete S8 fuel tank soon, but that's another story/thread ...
Well mines a 2003-reg, very late (2002 built) D2 S8 and the door key is very mechanical. Suggests something broken in yours.....
Ah, brilliant, thanks for that.
In that case, maybe mine is presently working entirely electrically and whatever mechanical linkage there should be is missing, broken or fallen off. That would make sense I think.
I was kinda assuming I'd maybe screwed something up using VAG COM, but I'm guessing it probably wasn't working before that. Time to Study ElsaWin I think, see if I can see what might be missing/broken.
Old 18th September 2014, 12:17 PM
Just to add that when I unlock the drivers door with the key only that door unlocks and the interior lights come on. The other doors unlock when the ignition is turned on.
When locking with the key all doors lock and the alarm chirps.
I assume that unlocking behaviour is down to the settings I have, I've changed them a fair bit (noted in another thread) with VCDS.
