Old 26th September 2014, 05:28 PM
IIRC in previous models you needed the login code for the donor part's car and yours. It also needed to be the correct immobiliser version denoted by the letter on the end of the part number. I hope ours are simpler as I would also like this.
Old 26th September 2014, 07:14 PM
You will quite possibly get component protection on the car when the Dash is swapped but I don't think you'll get immobiliser issues. It should just need a trip to the local Audi Stealer to get the component protection removed after swapping which is normally about £30-35
Old 26th September 2014, 07:31 PM
gninnam gninnam is offline
I found that none of the Audi Stealers round my neck of the woods would entertain doing the component protection code
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 26th September 2014, 09:14 PM
mannyo mannyo is offline
On the D3 the immobiliser is not part of the cluster, you can swap the cluster straight over and the car will still run.
BUT
Nothing will work correctly until the car has made a trip to an Audi dealer to have component protection removed.
Manny
Past
Old 26th September 2014, 09:56 PM
As above, it will run, but clocks wont work until you have trip to Audi to sort CP.
Note, I dont know how easy mileage correction is. D2 PF was ok, but D2 FL was only do-able with a soldering iron on a bench job.
Never looked into the D3, but I wouldn't assume straight forward unless you've come across examples of it being done, and I've not seen any....
Old 27th September 2014, 11:07 AM
Thanks guys
It looks like it wont be a straight swap
CP, is that done with VAS?? My guys got the VAS so they could do it for me as Bexley Audi is horrible with things like that.
Mileage correction. Ian, what exactly that involves, is there a chip on a pcb which needs to be transfer??
I thought it all easy done via VCDS in the main window where the mileage correction function is
Thank you once again
Old 27th September 2014, 11:26 AM
CP removal is done with VAS but it needs an online connection to Audi HQ, I assume that only main dealers have that. For most things VAS does not need an online connection, but for CP removal it does.
Manny
Past
