Old 1st October 2014, 01:13 PM
mannyo mannyo is offline
it should be a setting, the same disk and software is used throughout Europe. If you want to change to Norwegian it may need a new disk that supports your language but English should be no problem.
Manny
Past
Old 1st October 2014, 04:00 PM
NightOwl NightOwl is offline
If you are in lets say radio mode, press "setup" and then the button up right for the rotary button. The first line that appears on the screen should be menu languages.
Old 1st October 2014, 09:15 PM
Exerqtor Exerqtor is offline
Okok, let's just hope my self taught German is good enough to get to the language settings menu
Old 3rd October 2014, 02:12 PM
Have you sorted this?
It's easy...
ID:	9178   Click image for larger version
ID:	9179   Click image for larger version
ID:	9180   Click image for larger version
ID:	9181   Click image for larger version
ID:	9182   Click image for larger version
Matt
Old 3rd October 2014, 03:29 PM
Ah great! Im flying down to berlin in a couple of hours to pick it up. That wil come in handy! Thank you!
Old 4th October 2014, 09:20 AM
Though pretty sure that will reset itself as it's just MMI coding, at least gets you home though
Old 5th October 2014, 10:35 AM
It changed the spoken language to English as well, so i came home without a hitch ( well almost )
