Old 5th October 2014, 09:45 AM
D3 or D2, I am sure it must be the same controls? Resume is flick stalk toward you and set speed is press in.
Neil, you maybe correct as I was using a higher cruise speed further back in the journey. Worrying that if it was resumed the car down shifted and used full throttle to get back to speed!
Matt
Old 5th October 2014, 10:11 AM
D2 resume is designed to detach the fingernails of the unwary.
Seems odd it would downshift if resumed, 50 - 60 would be a gentle increase, unless you were heading uphill.
I wonder is the speed sensor misreported. Do they use the ABS sensors for that?
Old 5th October 2014, 11:06 AM
Nope. Quite different on a D2. Stalk is only moved for other functions (lights, indicators), cruise is awkward slider and a button, rather non-intuitive (to put it politely ).
Old 5th October 2014, 11:24 AM
Oh yes, quite different indeed!
Matt
Old 5th October 2014, 12:42 PM
Not wishing to digress too far, but there are even 2 versions of that D2 stalk and I believe they're incompatible.
That's the later version I think - [geekmode]the most visible clue being how the cable at the base of the stalk wraps round over the top as it goes into the block. [/geekmode]
Old 5th October 2014, 02:28 PM
I can only think that you re-engaged cruise rather than re-set it.. Mine does it. it's even more fun with ACC where it will randomly decide that an object near you is an obstacle, drop 20 mph, then floor it to get back up to speed
