D2 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
It's quite common on d2s fitted with 20s to see this pattern of wear - usually inner edge on the rears and outer on the front. My last set of tyres went in a similar fashion in terms of wear pattern. I did have a proper Audi spec alignment done and there were minor issues that cumulatively were contributory to the wear seen. There's a thread on here somewhere with the before and after results
I had similar wear (nothing as dramatic an end though) because I'd not checked the tyre pressure for a little while and one was very down. In the past I've always been able to easily tell when pressures are low by the way the car feels, but the wall on my 20's are so low and stiff, I simply didn't realise. I check more regularly now and am thinking about an aftermarket tyre pressure monitor (cheaper than a new set of Michelin's).
Really glad you're ok though! |
My Vredestein Sessantas wore in exactly the same way on my 20s, despite correct alignment. Looks like a failure to me....I was down to the canvas as well before noticing...
I need to do upper and lower arms at the front in the next couple of months....I wonder if that would contribute to this wear pattern? Zip
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
My upper and lower arms are pretty new and I had alignment done not so long ago
Your photo shows that the side channel cuts ("Sipes") are completely worn away on the shoulder indicating a large amount of wear when compared with photos of new Vredestein tyres on the web, where the sipes extend down over the shoulder whereas you have none left. I guess that hitting a pothole must have caused the weak area to blow out. Glad you are ok though.
