Old 27th October 2014, 07:13 PM
nakata nakata is offline
Default Rear torsen on A8 D2
Hi, this is my old project of rear torsen at D2. Use a V8 for donor with little modification to make the swap.
The car make less understear and more balance at handling.
Here is a pictures from swaping.
Next project was to make A8 -> S8, but is for other topic's.
Old 28th October 2014, 09:07 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
What's with the bearings and the rag?
What you maching down and why?
So the D2 rear diff is not LSD?
I thought it would be.
[center]
06 3.0TDI Quattro:
Options:
Old 28th October 2014, 01:20 PM
Not really, centre diff is torsen and rear and front are open diffs with EDL(electronic diff lock) as part of ABS or ESP where it applies brakes to the spinning wheel.
Old 29th October 2014, 06:53 AM
After manual transmission, this is my best mod.
Now thincking about on 3rd torsen (at front).
About bearing's is have differance at V8 diff and 01R (A8) differential. At V8 is bigger and need machine grind to make fit in at 01R diff.
Now A8 D3 4.2 40v Supercharged!!!
EX: A/S8 D2 4.2, moded done: Manual gearbox, Recaro seats, RNS-E + OEM Bluetooth with working MFSW, S8 converted engine, S8 susspension, Solar roof, RS6 brake setup and bigger servo and pump
Future mod: RS 4.2tt engine.
Old 29th October 2014, 09:03 AM
....." mods done: Manual gearbox, Recaro seats, RNS-E, Rear torsen, S8 mod engine, S8 suspension"....
Just a bit of minor tinkering then!
Old 29th October 2014, 03:40 PM
I made so many other small mod, but this is important's. Like my last one A8->S8 with better coil's.
http://www.youtube.com/watch?v=WHQqZ04GQpY
Old 1st November 2014, 11:09 AM
SilverS8 SilverS8 is offline
Please share your manual conversion in details
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 2nd February 2015, 03:13 PM
http://forum.a8parts.co.uk/showthread.php?t=5699
Here is flywheel
http://forum.a8parts.co.uk/showthread.php?t=9415
